show vm-tracking local-vm
show vm-tracking local-vm {mac-address mac}
Description
Displays one or all of the VM entries in the local VM database.
Syntax Description
mac
Specifies the MAC address of a VM database entry that you want to display.
Default
N/A.
Usage Guidelines
If you do not enter a MAC address with this command, the command displays all entries in the local VM database.
The following command displays the local database VMs:
# show vm-tracking local-vm
MAC Address        IP Address       Type              Value
00:00:00:00:00:21                   VM
                                    VLAN Tag          100
                                    VR Name           VR-Default
                                    VPP               vpp1
Number of Local VMs: 1
This command was first available in ExtremeXOS 12.5.
Platform Availability
